Will VRay be updated to run with Max 6 when it comes out?
I would like to think so.
:roll:
why shouldn’t they do it?
robert
Knowing the VRay development team, they probably have had this in the works for longer than we’ve known about the release of Max6. I would guess that it’s a non-issue at this point and the transition will be seamless.
I hope so 586, I just did the preorder thing ![]()
-dave
I would imagine that it shouldn’t be any problem at all considering that Max 6 is going to be pretty much the same as 5 but with the added features like PFlow and Mental Ray.
Cool, I imagined it would be so 8)
i found this on the cgarchitect.com website:
“Vray will be available for MAX 6, when MAX 6 is out. The MAX 5 version will not work, surely, but Chaosgroup is already working with Discreet to get a version for MAX 6 out in the market as fast as possible. So, most likely, when you get your copy of MAX 6, you’ll just need to download VRay.”
Its a quote from Alexander Bicahlo who works at Discreet.
sean
thaks Sean ![]()
We do have a recompile of VRay for Max 6; it mostly works, but still needs some serious testing.
Thanks for the reply Vlado, I’ll mail you when we get 6 incase you still need to beta test it. keep up the kick@$$ work ![]()
Well Vlado, all I can say is if I ever meet you and or Peter I’m soooo buying you guys a couple of rounds ![]()
-dave
