Max crashed
Hi developers! My max crashing after rendered some passes (count passes different), twice i see blue screen and my computer restarted. I thought it is ram, but scene very lite, and using 1200mb of ram max. It started yesterday, before everything was right. I don’t know what is this?
P.S. Sorry for my english))
Do you ever get blue-screen outside of Corona ? Usually it is rather related to hardware issue.
With that said, the single blue-screen I ever got in 3 years was during Corona render as well, but I still think it wasn’t connected :- ).
If you render with Vray or something else that taxes your CPU 100perc. for prolonged time, is that stable elsewhere ?
Quoting Ondra:
Corona or any other user software cannot cause blue screens in Windows NT or newer. Is it possible that your computer is unstable (and for example crashing under load)?
But maybe he will want to take a look at this issue.
Before this incident, everything was fine. I did not see a blue screen)))
And in the corona 1.0 I have worked since the release - everything was ok. I will continue to test.
Did you install any new hardware or changed drivers?
No. I didn’t.
minidump from autodesk screen
3dsmax_minidump.dmp (5.12 MB)
last minidump.. I hope Ondra will see this
3dsmax_minidump.dmp (6.37 MB)
What CPU do you have?
This
It seems there is a problem with your CPU. Try installing all windows updates, and check if the cooling is OK. This is probably not caused by Corona. More info: https://coronarenderer.freshdesk.com/support/solutions/articles/5000595168
Thank you, Ondra!
Same problem here. Max crashes on rendering passes (could be any pass), CPU and RAM checked, its fine. Problem appears just today, i’m trying to locate it.
UPD: Ooops, my fault. Memtest86 didnt find problem in RAM, but when i did “hard” test, taking out RAM plates one by one, i found broken plate, now everything works fine. Sorry for thinking bad about Corona ))
UPD2: Still the same problem, cannot run any rendering, switched back to vray, because didnt had other choise.
