Hello !
Using Vray 3.00.07.
was playing with a 1000*600 scene for testing dmc stuff, and defined a vertical strip for region observation.
(note : the y region was almost 600 pixels height)
i rendered many times with no problem with the region.
Then, i made a CTRL+S of the max scene, then rendered again. Max crashed immediatly.
Problem remains when reopening the scene in a fresh max.
i think i figured out :
just after opening the scene in a fresh 3dsmax session, if i hit the “show last vfb”, it opens with 640*480.
If i try to render with the saved region, then max crashes.
If i open the Vray Frame buffer (Show last), then remove the region, everything works fine again.
that means that i can’t save a “with defined region” scene if my render is biger than 640*480.
Hope it helps !!
