[MAXScript] check if VRay is installed
Since I’m developing a small script, I wanted to know whether it is possible with MAXScript to check if there’s a copy of VRay running or not.
Any suggestions?
Check the renderers.current or see if you can find a file used by vray.
findstring renderers.current "V-Ray"
If true, VRay is the current render.
Expand on the concept to check through all the renderers, just to know if it’s installed.
Lele
seems not to work in some way :?
if findstring (rendererclass.classes as string) "v_ray" != undefined then messagebox "success" else messagebox "bad bad bad"
regards, Michael
edit:
mystring = "" as stringstream
format "Renderers installed:\n\n" to:mystring
for i in rendererclass.classes do
format "%\n" i to:mystring
messagebox mystring as string
to show the handling better
http://forums.cgsociety.org/showthread.php?f=98&t=481656
Answer to this from the master Bobo
That’s what was posted here…
