I was wondering if any of you scripters could help me with something. I basically need a little script that will take, for instance a selection of three vertices and center the middle vertex between the first and third. Ideally this would work for an editable poly and/or spline shapes. Any help will be greatly appreciated.
The middle vertex is…well…imagine you start out with a 3 vert shape that looks like the letter V…but kind of tilted so that the two top verts aren’t at the samee elevation. Then you want to take that middle vertex and move it so that its exactly in the middle of the two vertices…as far as elevation goes. Hope that makes sense.
you are meaning to align the to the VIEW up vector? or to the Z position?
the code for the window alignment is slightly more complex, but the basic idea, once you have a reference coordinate system, is simply to average out the two transform matrices, and derive as such the third one.
------------ initialise the variable that will contain the matrices sum
theSum=[0,0,0]
------------ increment the total sum value by the matrix of each vertex i-Nth of the mesh $
for i=1 to (meshop.getNumVerts $) do (
theSum+=meshop.getvert $ i
------------ calculate the average position dividing the sum by the number of vertices
theAvg = theSum / (meshop.getNumVerts $)
------------ move the vertices in place
meshop.setVert $ i theAvg
------------ redraw required to see the meshop results
redrawViews()
```This will move every vertex of a given MESH object (or else it will fail, use a mesh select op on top of the stack to make sure it's read as a mesh) to the average position of all the vertices.
In a standard sphere, this represents the pivot location at the origin of the sphere.
Feel free to customize the code to suit your needs.
