(MAYA) Enabling Liquid in Sim seems to breaks Fire Source
Hey!
I was experimenting with fire and liquid and realized that the fire sim stopped working if I checked and unchecked “Enable” under the Liquids section. When enabled the fire acts as a liquid but when unchecked it renders nothing at all. I would have expected it to behave as it did before I checked the checkbox.
Perhaps this is already a known bug thats fixed in the Nightly builds?
Johan
What happens is that when your press “Enable” for the Liquids - we modify the preview and the rendering settings and when you turn it off they don’t get back to the previous state. If you manually dial those back to the way they were - you should get the same result.
Indeed now you can switch between liquid and fire simulations by flipping on this switch, but in the near future there will be two different simulators for fire and liquid just as in 3dsmax, so this won’t be an issue anymore.
Thank you for clearing that up!
I’ll be looking forward to the update with the simulators!
