Maya VRAY RT: // Warning: Render host xxxxx (127.0.0.1:20207) is not responding
in the last days and also in the past it happends so often that RT is not rendering/starting. sometimes i get that message.
sometimes i get no response and the scene is not rendering in RT. RT is started but nothing happens. I’m using type CPU.
Vray Build is..
[2012/Oct/24|10:26:43] V-Ray: V-Ray for Maya version 2.25.01, revision 22441 from Oct 17 2012, 02:28:24
[2012/Oct/24|10:26:43] V-Ray: V-Ray core version is 2.00.02
-- thats the complete log --
[2012/Oct/24|12:24:59] V-Ray warning: No image writer specified.
[2012/Oct/24|12:24:59] V-Ray: Preparing renderer…
[2012/Oct/24|12:24:59] V-Ray: Preparing scene for rendering…
[2012/Oct/24|12:24:59] V-Ray: Creating texture cache with size 0 MB
[2012/Oct/24|12:24:59] V-Ray: Creating bitmap manager
[2012/Oct/24|12:24:59] V-Ray: dr host: 127.0.0.1:20207
[2012/Oct/24|12:24:59] V-Ray: Connected to render host 127.0.0.1:20207
[2012/Oct/24|12:24:59] V-Ray: Using 1 hosts for distributed rendering.
[2012/Oct/24|12:24:59] V-Ray: Preparing scene for frame…
[2012/Oct/24|12:24:59] V-Ray: Running RTEngine
[2012/Oct/24|12:24:59] V-Ray warning: Render host madness4 (127.0.0.1:20207) is not responding
maybe this is already known, and there is a solution, but i didnt find something with the search forum function. :confused:
thx,
Kay
Can you provide the log from the V-Ray standalone?
It seems that the V-Ray standalone is crashing or just dropping the connection.
Also does it happen with a specific scene or it is scene agnostic?
/Teodor
nope. It also happens with a clean scene and just a sphere. stupid question. where can i find the standalone logfile?
Hm, strange.
When RT is started V-Ray starts an instance of V-Ray Standalone.
This instance is run in background, inside a command prompt window.
So you should be able to alt-tab to it.
Of course this happens if you’ve not registered the V-Ray slave as a service. Then it is not possible to see the log.
ok.. there is no VraySlave as a service running. just the VrayMayaSpawner´s and the VRLService for the licensing. I started the VraySlave manually and i get this..
[2012/Oct/24|14:35:12] Reading configuration from “C:\Program Files\Autodesk\Maya2011\vray\bin\/vrayconfig.xml”
[2012/Oct/24|14:35:12] ===============================================
[2012/Oct/24|14:35:12] V-Ray Standalone, version 2.25.01 for x64
[2012/Oct/24|14:35:12] Copyright (C) 2000-2012 Chaos Group Ltd. All rights reserved.
[2012/Oct/24|14:35:12] Use -credits option for additional third-party copyright notices.
[2012/Oct/24|14:35:12] Build 22441 from Oct 17 2012, 02:11:35
[2012/Oct/24|14:35:12] Compiled with Intel C++ compiler, version 12
[2012/Oct/24|14:35:12] Operating system is Microsoft™ Windows™, version 6.1, Service Pack 1
[2012/Oct/24|14:35:12] V-Ray core version is 2.00.02
[2012/Oct/24|14:35:13] Loading plugins from “C:\Program Files\Autodesk\Maya2011/vray/vrayplugins/vray_*.dll”
[2012/Oct/24|14:35:13] 135 plugin(s) loaded successfully
[2012/Oct/24|14:35:13] Loading plugins from “C:\Program Files\Autodesk\Maya2011/vray/vrayplugins/std_*.dll”
[2012/Oct/24|14:35:13] Finished loading plugins.
[2012/Oct/24|14:35:13] error: There is another server already running.
[2012/Oct/24|14:35:13] Exiting server mode.
[2012/Oct/24|14:35:13] Closing log - 1 error(s), 0 warning(s).
The error is pretty clear. But i dont know why the log is saying there is a server already running? i dont see the vray standalone service and maya is closed at the moment.
I think i will uninstall all the vray stuff and reinstall it again. maybe that helps..
In fact this is the service.
You have to stop it from the service management and try again to render with RT.
ah okay. but i’m sure i did that a few times. however i deinstalled everything, vray 2011-2013, Phoenix for Maya. And just reinstalled vray for maya 2011 and now it works again.
its strange that i have that problem already since a few weeks and the service was not running correctly after rebooting the system and all that stuff.. hm
but thanks for your support.
Kay
Is there a solution to this problem? I am using Maya 2012 nightly build in windows and I can’t start RT. There is no V-Ray service running on the machine.. Actually all workstations are having this issue as well.
// Warning: Could not use any of the selected (1) hosts for distributed rendering! //
mdskay, one thing to try is using your machine’s local IP as an alternative to the default localhost (127.0.0.1).
open a Windows command prompt, type ipconfig and hit enter. Note your “IP address” and use that as an alternate in Vray’s license server.
Bear in mind that by default Windows grabs a new local IP whenever you reboot your router so in order to not need to repeat this process, you’ll need to set up a static IP www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
Note I have no idea why I need to do this in the first place, because the default 127.0.0.1 should always just refer to the local machine, but even after disabling any security software it doesn’t work so I’m forced to point Vray to my machine using the aforementioned method. I’ll have a look at my hosts file actually, come to think of it…
I am using a static IP for this machine. Edited DR settings to try and force just the ip address, along with editing the windows hosts file to remap. No luck. Thanks for the help though.
Metzger can you post the full logs from maya and the standalone?
/Teodor
