I am using a simple bat command in the powershell:
D:\Autodesk\Maya2023\bin\Render.EXE -r vray -proj M:\Methan\B03\1_Maya -threads 40 -s 0 -e 4 M:\Methan\B03\1_Maya\scenes\test_render_v01.ma
D:\Autodesk\Maya2023\bin\Render.EXE -r vray -proj M:\Methan\B03\1_Maya -threads 40 -s 5 -e 10 M:\Methan\B03\1_Maya\scenes\test_render_v01.ma
PAUSE
Vray renders the first package, but the bat does not start the second package. It just stops there:
[2022/May/4|18:25:29] V-Ray: Moving hair segments: 0
[2022/May/4|18:25:29] V-Ray: Successfully written image file “M:/Methan/B03/1_Maya/images/test_render_v01/test_render_v01.0004.png”
[2022/May/4|18:25:29] V-Ray: Total frame time 0h 0m 0.9s (0.9 s)
[2022/May/4|18:25:29] V-Ray: Total sequence time 0h 0m 5.6s (5.6 s)
[2022/May/4|18:25:29] V-Ray: Render complete
[2022/May/4|18:25:29] V-Ray: ========================
[2022/May/4|18:25:29] V-Ray: Clearing exporter memory…
[2022/May/4|18:25:29] V-Ray: Total time clearing exporter memory 0h 0m 0.0s (0.0 s)
Scene M:\Methan\B03\1_Maya\scenes\test_render_v01.ma completed.
The CPU is idle the first 4 frames where rendered.
The scene is just a sphere, plane and spotlight …
The same scene rendered with maya software does render through
Windows 10 Pro
V-Ray 5 for Maya, update 2.2
(v5.20.02, revision 31396 from May 2 2022)
The problems began afther I upgraded from maya 2021 and vray 4 to maya 2022 and vray 5 at the same time.
I do have this problem on multiple fresh installed machines …
THX in advance
Cheers Christian
