Mesh material
Can anyone show me how to make a mesh material? like something you would see in a mesh cloth. I would need the perforation to be transparent.(see image)
Thank you!
Re: Mesh material
here’s mine,might not be perfect but it works,and you can learn from it.
www.merlik.com/vray/mesh.zip
hopes it helps,
Renee
Re: Mesh material
Renee,
I am having similar issue. I was able to apply transparency through png image, but that is mapping the mesh itself to become partially transparent instead of solid.
Any tips or can you post your zip again.
Thanks.
Re: Mesh material
Hi Luis,
Posted again.if you want something in the hole just add another diffuse layer.
Renee
