MIP_CAMERAMAP in Vray?
I have a work of liveAction, and I do not find something similar to mip_cameramap (mentalray), im try use camera projection, but not the same effect.
Im found in forum, same question this post in 2010, but not solution. :frowning:
VRayMtlWrapper would be useful for receiving a reflection from an object. What I am trying to do is a bit different. I want to project the film plate (say of a table top) from the camera onto an object (say a model of a table) that had its primary visibility off. That way this object (the table) will not render, but an object sitting on it (say a chrome salt shaker) will properly reflect the film plate (the table top).
Here is a pic of the difference between the result of the Maya projection from the camera (wrong) and the mental ray mip_cameramap which gives the correct reflection on the sphere. This is from p 38 of the mental ray - Production Shader Library manual. What I am after is a vray node that can do what the mip_cameramap can do:
Try something like this. We should really make it more easier though, like in 3ds Max - turning on “matte for all secondary rays” should be enough, without the need to override the environment of the matte material to use projection mapping.
matte_test.zip (8.04 KB)
Hi Vlado, Works fine! Really Thx!
Vlado is this your computer at work :)))
Hehe yes, why?
It reminded me of back home (Ukraine) how we had things…:slight_smile:
Hehe… I have to plug different things (mostly GPUs) into it so often that I just keep the case open all the time :slight_smile:
