I was used to using the native Cinema Bitmap shader. It allowed me to select the SEAMLESS option on the material node, and it worked perfectly. To get the most out of Corona, I started using Corona Bitmap. The node’s SEAMLESS function no longer works. I investigated the UV TILING area of the material editor, and there is no option for MIRRORED TILING. I checked the Corona manual, and this option should be present. Any ideas on how to mirror the texture while using the Corona Bitmap shader?
Have you tried changing the U length to -100%? This should mirror it. Or you could connect it to a layer shader, add a transform filter and mirror it there.
c4d mirrored tiling, what he means in c4dm, is some completely other feature, it iterates normal and mirrored to make a kind f automatic seamless mapping
Ben, this is just a bitmap mirroring, this is NOT what the seamless mode does. what you show is something completely different. the Q was not about mirroring a bitmap i think.
the seamless mode does some different, you can try it with a c4d bitmap then it should be clear fast. it is indeed a useful mapping feature from c4d.
Ahh what an idiot, the read the whole thing completely wrong lol. Okay, I’m with you guys. I agree, it’s not working and I’ll make a report of it. Sorry for dragging this out
