Missing maps on client when using DR
I have two machines running Vray advanced 1.0903g.
One is running as server and client and the other one is just a client.
I have a scene that I wish to render using the DR. All materials has been setup using UNC - so they should (and do) work over the network.
The problem is - I can render the image running max from the client NOT using DR and get a correct image WITH the map, but when i render the image from the server using DR and both machines I only get mapping on the server buckets.
Any :idea:´s are very welcome.
razz,
maybe late … well you can use maxs’ network rendering and check INCLUDE MAPS in network render dialog.
tomas.
I have had the same exact problem for the last few vray versions. UNC paths are working fine. Once in a great great while I’ll get a full imge.
Tom4ski-Include map is a feature of Backburner (max’s network rendering). Are you saying you are using backburner and render to VRAY DR? I never considered this an option for stills.
Corey
Corry, i’m sorry. it was my nonsence. i’m using max-net render only.
just in case .. this might help: http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=2477
tomas.
For peace of mind…is anyone using DR with the latest build and getting consistent results? with no network mapping problems?
corey
