Missing Material/Map
Hi all
Recently I find the material editor always shows a rollout between Basic parameters and Coat Parameters, the rollout calls Missing Material/Map, and the words shows below: this class does not have an implementation supplied by any of the currently loaded dll’s
Someone could give me some clue to solve this?
Thanks alot
It just means that the material originally had a component used by e.g. a specific plugin which you don’t have installed.
So it happens with 3rd party models for instance, where they had some old map plugin or something like that.
It won’t do any harm leaving it as it is, though you can just recreate the rest of it in a new shader if you want it to go away.
Thanks alot for your help
