Enable or Not Enabled - - no file is saved.
Solution ?
Nir
Solution ?
Nir
are you splitting the render channels in the vray frame buffer? or are you saving to an EXR?
Vray Frame buffer
I dont work with EXR as I only output it to Photoshop
Nir
unless you save to a format which supports multiple channels, elements won’t be saved in a single file. as jack suggests you can split them, and have each channel as an independent file.
Will check this option- I never knew it existed.(usually not using VFB)
