Hi all
I have this problem _ I use more than 1 MultiMatte render elements and the Frame buffer - upon rendering only saves 1
I do see all of them in the dropdown list but after the render process ends - only one gets saved. (names are distinct - I made sure)
The one that is saved ignores the name I gave it under the render elemenmts UI
Same goes if I try to save the channels manually from the VFB UI (the multi floppy icon)
EDIT: SOLVED - I had to rename the elements in NAME and not only where the full path is (which is unintuitive since there are 2 places where one can change the output file name)
regards
NIR
