Can you please share the scene with us? It will help us investigate and find the issue. If it’s more convenient for you, you can share it in a direct message to me.
All the latest updates were used Maya 2020.4 Latest VRay release and cloud client.
I was wondering if some of the referenced assets had brought in some render elements? but these would have had a name space anyway.
Is this forum still active? 2024 and having same error. Constantly actually. “Multiple render elements with the same name are not supported”. Any solutions? When I delete all elements it works, once I start adding few, same message pops up.
Hi, thanks for posting. Which host platform are you using (is it Maya)? Please update your V-Ray to the latest version and re-install the Cloud Client App.
Is this issue happening in a new simple scene? What render elements were you using when you got the issue? Please share your scene that reproduces the issue here or on the support contact form.
I tested the scene form post number 3. It is a Maya scene and it submits and renders without issues on my end.
Hi, I have the same problem with v-ray in Rhino. I could upload my first scene with all the render elements i needed, but with the next two i had the same problem as everybody above. I already updated everything and it is still not working. Do you have any other suggestions?
Hi, we have a bug report in our system that seems just like your case. Do you have BacktoBeauty render element in your render elements stack?
Do you experience something like this:
Thanks for the quick reply! I didn’t have the back to beaty element but the light mix was the problem, once I removed it I could upload my file. But it didnt show up twice in the list and. Also the first scene still works with the light mix render element, but the other two dont
Hi, please open a ticket to support and include a link to this thread as well as your job ID in the description.. We need to review the scene to confirm what the issue is.
