There’s any way to export multiple render layers on the same vray scene file? When I export it only exports the master layer.
Thank you for your help.
You can export all renders layers (in batch mode), but each render layer will have one vrscene.
You can not have all renders layers in one vrscene.
Yep, you can export all layers - each one will end up in its own .vrscene. The .vrscene file format itself has no notion of layers at all.
