MultiSubTexture randomizer does not work with Proxies
Hi there
I am using Vray 5.20.23 in GPU mode.
Are you (Chaos Group) aware that Vray Proxies doesn’t support the multi sub texture option to randomized instances in a Chaos Scatter object?
Only when transfered into a scene mesh does the effect works. (set to instance ID as per documentation)
Works fine in the latest official V-Ray 6 version. Judging by your other thread, you are downgrading ChaosScatter (most likely to Corona’s Scatter Pro) to render with V-Ray 5, so it is expected to have some unsupported functionalities.
