This is my first posting out here… but kick me with tips and critix…
I have this scene with an american store at the window…
I have difficulty with the material and lighting… I get splotches.
Could this be because I have the subdivs of the refraction slot set at 2?
Or should I use translucent (don’t know how).
The material settings are attached.
The lighting is :
IR: High presets,
2 Vray lights (sphere with skylight portal on, subdivs 10). One at that window and one at the back.
Also How do I get the walls more brighter.
I saw a technique in this forum of a set of lights (vray) with different light multipliers from outside the wall, entering the interior.
I did 2 scenes… daylight (IR=low presets) and daylight with IES spots on (High presets, woosh IR map took ages (maybe 2-3hrz on my dual xeon Probably because of the IES).. Rendering was 17 minutes Could time be increased ?
The black one in my opinion. Just doesn’t appear as refined as other elements. break it up with a subtle texture or something of the like. Of course thats depending on what your going for. When I create Arch Vis work, I tend to try and create a piece of art as supposed to clean elements that a client would rather see.
It looks like a vray light the length of the wall set to invisible and 2 sided. A low enough multiplier and it might not blow out the wall enough to keep it from looking like that. My best guess.
DOn’t understand what you are trying to say percydaman. You mean that my curtain produces too much light ?.. I have only 1 vray light behind my curtain. The curtain is a vray material with a tiles map and refraction with glossiness…
The carnaval was a combination of a vray material and imported geometry I think, because applying another material to the new objects didn’t do anything.. deleting them complete did it.. still didn’t have the time to reimport them. Strange…
I’m sure it’s a material issue on the imported object(s).
Import the object into a new-MAX scene, and do the materials (all Vray) there. Merge this into your current room-scene (I sometimes find this easier than doing it in my main scene).
Regarding the Carnival - Someone didn’t maybe sneak in overnight while you were asleep and have a paintball fight? :lol:
