In the Material/Map Browser I often type the name of a specific map to find it quicker but the problem here is that all the Corona maps start with “Corona”. Wouldn’t it be more convenient to change “Corona” into just a simple “C”? So for example instead of “CoronaBitmap” it would be “Cbitmap”. now you only need to type “cb” to quickly find a “CoronaBitmap” map.
I am aware that when using the SME it isn’t a big issue but I still like to use the old fashion CME.
I haven’t thought about the implications of your request, but I have two workflow suggestions.
The first suggestion is that you can type c*b to quickly find a CoronaBitmap map in the Material/Map Browser’s search field.
The second suggestion requires some preparation. Open the Material/Map Browser’s drop down menu and create a new material library and name it for example favourites.mat, then drag and drop in this new library a CoronaBitmap and rename it as CBitmap. You can now type cb to quickly find a CoronaBitmap map.
