can someone help me with tweaking and explaning the Vray2SidedMtl for my Leaves. (A Max 2017 / 2018-File with my textures is attached)
The only Tutorial i found was this one:
But this didn’t helped me very well.
As a starting point I used a sample tree from Evermotion: (SAMPLE TREE)
AM176_017
What I can not understand is why I have to use a Map for the Translucent slot in the Front Material. If I disconnect this Map I get a grey Back Material. But why???
Just to understand that I am on the right track: (for the vray2sidedmtl)
When a light (the Sun) hit the leave, the leave will be transparent. But in shadow areas the leaves will show the front/back Material (depending if you look from top or bottom)
Mediaeffects:
but what do you do when adding a backside material to the leave? Youd need to ad some translucency map there as well no? To have a proper mix.
