I replaced Revit material with Vray from asset library, but result is not unsatisfactory. How can it be fixed.
Thanks in advance.
Hello @veent_veent ,
Where is the chair model taken from? Apparently, it is a Revit family but where did the geometry came from? Was it built in Revit or imported from somewhere else?
Best,
Ana
Model was made in Rhino.
Dear @veent_veent , hello.
The UVs are inherited from the host platform where they were set.
It will be beneficial to send us the .3dm file, if possible as a Packed Scene (V-Ray > Pack Project), of course if you are using V-Ray for Rhino.
If not - only the .3dm and the initially used textures.
You could upload the archive here or via our contact form. Just please add the forum link in the description.
If you import one Cosmos object and try to edit and replace its materials you may not meet issues, since the UVs are set correctly.
Sharing this as an example to try.
TS
ok, I got you! Thanks, at first I’ll try to work with UV’s in Rhino (think it is main issue in my case) and then other ways…
Okay, keep us posted.
