TRYING TO RENDER…
I DONT KNOW WHY THE LIGHT IS LEAKING FROM THE ENV…
VRAYSUN+VRAYSKY+VRAYCAM…
KINDLY HELP IN A TOTALL MESS,
HAVE A SUBMISION ON 02-12-2011.
TRYED REMODELLING THE FLOOR AND WALL AND CEILING BUT SOLUTION.
VALDO I HAVE MAILED THE MAX FILE TO javid.imanov.
VALDO PLS SAVE ME THIS TIME.
ITS NEVER HAPPENED TO ME BEFORE
Strange. I hope you get it sorted out for today!
Are any of your light maps (irradiance or light cache) rendering from saved file? I’ve accidentally done some renders from saved irradiance maps after changing geometry.
Otherwise maybe try turn off lights one be one in vraylightlister (just vraysun in scene?) and render with low test settings. then maybe try turning off groups of geometry, and see if it clears with any of the objects hidden. sometimes objects with standard materials can cause excessive colour bleed, but doesn’t look like that’s the issue here. any vraylight materials in the scene?
Sometimes when i have problem files i select all geometry ‘save selected’ as a new file, then reset 3ds max and merge into fresh scene. maybe without lights and add new lights?
