Negative values for Ptex displacement are being clipped
I’m trying to figure out how to get these sub-zero values from being clipped at render time and the documentation mentions that you can use the Displacement Control to adjust the min and max value but nothing changes if I adjust those. I know the map is fine because I can adjust it in Mudbox and it has smooth transitions:
EDIT: Resolved (PEBKAC)
also, allow negative colors is on in Render Globals
Hm, this is weird. Can you post some example file? Or I can make something in Mudbox…
ok – I got it working after I noticed that displacement was set to vector and not normal. Looking in the wrong place. Sorry about that. Looks good now.
