Maybe I’m missing something, but is there a documentation on how to use the new toon shader which is found in the recent daily build?
When I use it on an object it turns invisible…
https://forum.corona-renderer.com/ Toon + Outline Mtl Playground!
In the Max forum you can find a few pointers..
HTH
Documentation always comes along at or after release, along with tutorials too - this is because there can be changes to the UI and functionality while things are in development, so trying to document too early would lead to much “chasing of your own tail” and continually having to adjust it ![]()
Meantime, if you share a screen grab of your material set up (or your scene), plus what you are seeing in a render, folks can help you with what is wrong with the set up and get you up and running!
You can as well enhance the human model with AI Enhancer, available in the v13 DBs and also coming soon in v13.
Huh??? Can you explain to a old dinausaur???
Ah sorry, my bad, I thought this is 3ds Max daily builds section (it is available for 3ds Max DBs).
