New VFB Skin and functionality
Can we put suggestions in this thread?
I’m here to raise a hand for custom background or reference image overlay, that maybe works like A/B history so you can compare your render to any image of your choice. Color management here is of course priority otherwise the feature is completely useless.
I want to A/B my current render to either my own renders of the same scene/product or reference images.
could we PLEASE add a function to FLIP the image horizontally - just to refresh the eyes to look at the render from a new perspective.
+1
And composition lines please
+1
It would also be nice to have an option to change the VFB background color in Corona Renderer.
This was discussed previously here: https://forum.corona-renderer.com/ VFB Background Color + Multi LUT
It really helps a lot when you need to adjust the overall brightness level of the rendering, because with the current linear RGB 4/4/4 background color, it is easy to miss it.
They are logged.
Flip/rotate the VFB content: (Report ID=CMAX-862)
Change VFB background color: (Report ID=CMAX-861)
Am I the only one who would like to draw hand free the region zone?
Is it possible to implement?
Thank you,
Manuel
Since you’re bringing this up, it would be great to be able to mark the region in either the viewport or the VFB, not just the VFB.
But yes, a freehand region selection wouldn’t be bad if not hard to implement.
You can already define render region in viewport, or native one from max aren’t sufficient enough?
Now when I think about it. Will new vfb brake batch exporter script, or it will work with new image editor?
Or even better, do you have plans for inbuilt tools in image editor itself?
Saw the new VFB today, cool and I like it! :smiley:
Stupid question, what’s the meaning now of aplying the LUT also in linear mode? How should be used???
Thanks!
Hi
Im testing the new VFB, its pretty cool, I think you could improve a little bit if possible
Could we have a separate button for IR and resume Last? theres some space that can be used
Could we have a shortcut for 100% or adjust image to vfb window with double click (left)
Could we have a history settings here instead of in render setup System settings?
I have been wishing for a long time that we could have a permanent render history (in previous versions all images dissapear when closing 3ds max) for what Im testing in this daily if I use a custom folder, images are store in there, but if I use the trash can button images are deleted, could we have those deleted images in the recycle bin? Could we have a multiple folders for each project like in Vray? in there you can specify the folder from the Project folder
UI is still in progress.
For permanent render history - there is trach can icon and X icon, one clears from render history and the file stays on the drive, the other deletes all together. There is also sweep icon for batch clear and delete.
If you change the folder, every next history add will be stored in the new folder. This is currently stored as a parameters for each 3ds Max. Making it per-project can be a nice idea.
I tested the new VFB a little, I really like it so far, there are a couple of comments that I would be glad to see at the release stage.
  • return the spinning emoticon, firstly, it has already become canonical, and secondly, it clearly shows that rendering is in progress - now, apart from the noise of the fans, it is difficult to understand whether the interactive is running. (Play/stop indicators are made in b&w gamma, which does not have a very good effect on readability)
  • add a button to enable and disable interactive denoising (and, maybe make a drop-down list with a choice of its type), now I use a script and a hotkey for this, but a button would be a great addition
  • make a smoother step when zooming, this is still sorely missing
  • make “Start IR” as a separate button, and not from a drop-down list - this function is obviously used even more often than launching a regular render, so aiming at the small arrow every time is not the best solution.
  • detachable Curve window
  • maybe you can integrate switchable “image upscaling factor” parameter right into VFB, like x1/x2/x3 buttons. Personally, when using 4K monitors, I often tweak this parameter, finding a balance between detail and performance. This point also includes the ability to enable 2d pan zoom / real zoom in VFB
I know that most of this has already been logged, I’m just sharing my impressions, thanks!
Hello Guys,
I hope you are all well! I wanted to share my opinion about the new look of the VFB. Personally, I think it would add some sophistication and visibility if the buttons with certain features were as shown in the attached image.
Thanks a lot!
+1 !
Thanks!
To be honest - what I miss most is smooth stepless zooming, for some reason I was sure that we would see it after rewriting VFB :smiley: but well, let’s hope for the best
+1
I tried the new vfb and have to say its design is really stupid.
