New VrayLightMtl in SP3
It seems like emiting only indirect illumination…
Which GI engine did you use?
In any case, take a look here:
As you can see, the final result is a combination of direct lighting and GI.
I’m using Irrmap.
For your coments i supposed the vraylightMat works like vrayLight does.
Can i get only direct light with vrayLightMat if i disable GI?
Yep, it will work if you disable GI and turn the Direct lighting option on.
Direct light does not work when used in a Multi/Sub-Object material. Is that correct? At least it didn’t for me.
Can you disable GI for just that material using the VRayMtlWrapper on the VRayLightMtl…or will that mess up the direct lighting also?
I would test myself, but it may be a week or two before I get SP3 installed due to workload.
It will mess up the direct lighting.
I experienced that as well
any solution ?
NIR
oh come on guys..isnt that nit picking???
if it doesnt work with multisub, then dont use it period.
from the online help:
The direct illumination options currently only work properly if the VRayLightMtl material is the only material applied on the object. They will not work if the material is part of a complex material like a Multi/sub-object material or a VRayBlendMtl material. This restriction will probably be removed in a future release.
thanks for pointing that out
Thanks for pointing that out PixelJockey. Was about to pull out hairs..
I’m pretty sure this is a known “bug”. And by bug I think it’s a design feature or something, ie. it’s intentional. Something about it not being able to emit from a matID - it’s either the whole object or nothing.
I bring up this thread to post a problem with vraylightMtl direct illumination option.
In the attached image you can see the same plane, the first with vraylightmtl direct illumination ON and the second with a vraylight with mesh option enabled appiled.
The first doesn’t cast any shadow and direct illumination
The vraylightmtl isn’t part of MultiSubObject.
Theorically there shouldn’t be differences.
What’s wrong?
Thanks in advance
Does the light plane on the left have direct illumination on or off?
yes.
the left vraylightmtl with direct illumination ON
the right vraylight with mesh option ON with the same plane “linked”
Same intensity
