VrayLightMtl error when in multi/sub object Material
Hi
Put a Vray VrayLightMtl in a multi/sub object Mat and tick direct illumination on and there is no light.
If direct illumination is off it works.
Problem happen both in gpu/cpu mode
/Nikolaj
Hi Nikolaj,
What version are you using? We had a problem with nested light materials with direct illumination ON in 3.60.01 but it was fixed in 3.60.02. Anyway VRayLightMtl in Multi-Sub mtl with direct illumination ON is not supposed to work (it will act as it’s OFF).
Hi Peter, my bad I am on 3.60.01. Will update thanx
