i don’t know how to post images, but the problem was all the shelves of the bar were wengé veneered and since the bar itself is not brightly lit the whole thing came out be one brownish thing.
subtle glossy reflections from a hdri might works the best i guess as brightening the texture turns it to a walnut or something.
I don really want to change the settings of the material either, cos in real furniture, it is sort of matte…
I understand what you mean…I ve been through exacly same problem…
I Thik Ill just turn the fresnel off and put refl falloff distance/camera and Ill put something inside the window…than it should catch some more light…
Im working in the furniture design, and I came across the same ploblem with black materials/wood especially using Vray. Your problem has nothing to do with Fresnel reflection, I would definitevly uncheck this option in this case. Actually what makes a good black material it’s the reflection. Most wood surfaces are never completely flat like mirrors, if you look closely they have veins and cavities. This will affect the refection. For that reason you should make a specular map to get correct reflections,.. desaturate your diffuse/color map and copy it to the specular slot will work most of the time, and set the spinner at 50% or so depending on the surface. Get a vray light instead of skylight in windows. One workaround in Vray is to use the hilight only plugin as a shellac material. If this doesn’t give you satisfactory results make a second pass with specularity only and compose them in photoshop…I would like to post some illustrative examples but dunno how, if anyone can help???
