newbie questions
Hi Guys,
I am a newbie to Vray, I had been using Flamingo.
I have a couple of, I think dumb questions.
1. I haven’t been able to go to some of the linked websites in this forum that have tutorials etc., not sure why?
2. I am just wanting to attach a simple map (wood image) to a surface, which I think I am doing right (via diffuse - map attachment) but when I render I don’t see image.
If I could go to some of the linked tutorials I probable would be able to sort out question 2.
Anyway thanks in advance for your time.
Cheers,
Cian
Re: newbie questions
1. Home page → support → tutorials (the old links dosn’t work anymore), also try this
2. Open material editor, click on “diffuse” of a material → “m” → texture user interface → “m” → assign a map … → right mouse button click on the material name → assign to object
Best you read the material tutorial, here the new link: Chaos: Industry-leading design and visualization software
Hi Micha,
Thanks for the reply.
1. I did get to the tuts this way, just thought there was others I couldn’t get to. I also downloaded your starter kit 2, just need to read through in regards to the hdr files.
2. The same as the way I had be doing it (I am assigning to layer instead of surface), still however don’t see the image, it will be similiar in colour only.
Is it possible to get a test file sent through, already set-up just to make sure I’m doing it right.
Thanks in advance for your time & I look forward to your response.
Cheers,
Cian
Don’t forget, there is a beta 1 bug - you must set at the material properties → mapping → a custom mapping channel 1. Best keep your eyes open for the bug section. Let me know, if you need a sample file, but it should work now.
Hi Micha,
Tested and works.
I knew it would be something simple.
Yet again thanks very much for your time and i’ll be checking the bug section in future.
Now to go and play ;D
Cheers, Cian
