hey guys
I having trouble rendering materials that use VRayOCIO corrected textures on Vray Next 4.02.04 GPU cuda.
Is VRayOCIO not yet supported on cuda GPU? it`s working fine on regular CPU version of the same build.
hey guys
It’s not yet supported on the GPU. In order to support OCIO on the GPU (and to support an ACEScg workflow better in V-Ray generally), we plan to make some changes in this regard. It would help if you can tell me a bit more how you use VRayOCIO? To correct VRayHDRI/Bitmap/VRayColor textures, or for something else?
Pretty much just using VrayOCIO map to convert VRayHDRI bitmap to ACEScg for color maps(diffuse,reflection etc). Blurs pipeline, i`m sure you know…
Hm, that is supposed to work actually, but we’ll take a look.
