Nightly Build vray_adv_50050_houdini18.5.462 (MAC OS X) can't render
I get a script error when trying to Render anything with V-RAY in Houdini 18.5.462 on MAC:
I am using:
vray_adv_50050_houdini18.5.462_71834d6_10350_mac.zip
No module named _vfh_ipr
Traceback (most recent call last):
File “vray_render_start_ipr”, line 1, in <module>
File “/Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home/scripts/python/vfh/vfh_toolbar.py”, line 46, in vray_render_start_ipr
vfh_rop.render_ipr()
File “/Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home/scripts/python/vfh/vfh_rop.py”, line 156, in render_ipr
render_ipr_from_vfb(vrayRop.path())
File “/Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home/scripts/python/vfh/vfh_rop.py”, line 149, in render_ipr_from_vfb
import _vfh_ipr
ImportError: No module named _vfh_ipr
Cheers,
Helge
Is your Houdini a python3 build? Python 3 builds are not yet supported.
no, it’s a 2.7 Build. I’ve attached my Houdini_info.txt
Tested it with todays nightly build - same problem.
Regards,
Helge
Houdini Version 18.5.462
Operating System: Mac OS X Version 10.15.7 (Build 19H114)
Number of Cores: 8
Physical Memory: 16.00 GB
Number of Screens: 1
Screen 0: 2048 x 1152 at 0,0
Work Area 0: 2048 x 1129 at 0,23
Screen 0 DPI: 86.3
Build platform: macosx10.14-x86_64-clang10.0-targetosx10.12
Python Version: 2.7
Qt Version: 5.12.6
UI Scale: 2.000
OpenGL Vendor: ATI Technologies Inc.
OpenGL Renderer: AMD Radeon Pro 580 OpenGL Engine
OpenGL Version: 4.1 ATI-3.10.19
OpenGL Shading Language: 4.10
Detected: ATI Consumer (Mac version)
Unknown VRAM
3.10.19.0
Supported Extensions not in OpenGL 3.3 (Version):
GLX_SGI_swap_control
GL_ARB_draw_indirect (4.0)
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_texture_cube_map_array (4.0)
GL_ARB_texture_filter_anisotropic (4.6)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
Unsupported OpenGL Extensions used by Houdini:
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_bindless_texture
GL_ARB_buffer_storage (4.4)
GL_ARB_clear_buffer (4.3)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_copy_texture (4.3)
GL_ARB_debug_output
GL_ARB_multi_bind (4.4)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_shader_atomic_counters (4.2)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_shading_language_packing (4.2)
GL_ATI_meminfo
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_KHR_debug (4.3)
GL_NVX_gpu_memory_info
GL_NV_gpu_shader5
OpenGL Limits:
ELEMENTS_VERTICES 1048575
ELEMENTS_INDICES 150000
VERTEX_UNITS 128
TESS_CONTROL_TEXTURE_IMAGE_UNITS 128
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 128
GEOMETRY_UNITS 128
FRAGMENT_IMAGE_UNITS 128
COMBINED_UNITS 128
TEXTURE_SIZE 16384
3D_TEXTURE_SIZE 16384
CUBE_MAP_TEXTURE_SIZE 16384
RECTANGLE_TEXTURE_SIZE 16384
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 8
MAX_DEPTH_TEXTURE_SAMPLES 8
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 16384x16384
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 4096
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 16384
GEOMETRY_OUTPUT_VERTICES 1024
UNIFORM_BLOCKS 80
UNIFORM_BLOCK_SIZE 65536
UNIFORM_BUFFER_BINDINGS 80
COMBINED_VERT_UNIFORM_BLOCKS 16
COMBINED_VERT_UNIFORM_COMPS 266240
TESS_CONTROL_UNIFORM_BLOCKS 16
TESS_CONTROL_UNIFORM_COMPONENTS 4096
TESS_EVALUATION_UNIFORM_BLOCKS 16
TESS_EVALUATION_UNIFORM_COMPONENTS 4096
COMBINED_GEO_UNIFORM_BLOCKS 16
COMBINED_GEO_UNIFORM_COMPS 266240
COMBINED_FRAG_UNIFORM_BLOCKS 16
COMBINED_FRAG_UNIFORM_COMPS 266240
TRANSFORM_FEEDBACK_INT_COMPS 64
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 1 - 1
LINE_WIDTH_GRANULARITY 0.125
POINT_SIZE_RANGE 1 - 8191
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform Apple
Platform Vendor Apple
Platform Version OpenCL 1.2 (Jun 8 2020 17:36:15)
OpenCL Device AMD Radeon Pro 580 Compute Engine
OpenCL Type GPU
Device Version OpenCL 1.2
Frequency 1200 MHz
Compute Units 36
Device Address Bits 32
Global Memory 8192 MB
Max Allocation 2048 MB
Global Cache 0 KB
Max Constant Args 8
Max Constant Size 64 KB
Local Mem Size 32 KB
2D Image Support 16384x16384
3D Image Support 2048x2048x2048
OpenCL Platform Extensions:
cl_APPLE_SetMemObjectDestructor
cl_APPLE_ContextLoggingFunctions
cl_APPLE_clut
cl_APPLE_query_kernel_names
cl_APPLE_gl_sharing
cl_khr_gl_event
OpenCL Device Extensions:
cl_APPLE_clut
cl_APPLE_gl_sharing
cl_khr_gl_event
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_byte_addressable_store
cl_khr_image2d_from_buffer
cl_khr_depth_images
cl_APPLE_command_queue_priority
cl_APPLE_command_queue_select_compute_units
cl_khr_fp64
Environment:
ACTIVETAKE Main
ADSKFLEX_LICENSE_FILE localhost
CUDA_CACHE_MAXSIZE 268435456
DELIGHT /Applications/3Delight
H /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources
HB /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/bin
HDF5_DISABLE_VERSION_CHECK 1
HFS /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources
HH /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/houdini
HHC /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/houdini/config
HHP /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/houdini/python2.7libs
HIP /Users/helgemaus
HIPFILE /Users/helgemaus/untitled.hip
HIPNAME untitled
HOME /Users/helgemaus
HOUDINI13_VOLUME_COMPATIBILITY 1
HOUDINI_DESKTOP_DIR /Users/helgemaus/Desktop
HOUDINI_OS MacOS
HOUDINI_PATH /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home:/Users/helgemaus/Library/Preferences/houdini/18.5/packages/../SideFXLabs/18.5.469/SideFXLabs18.5:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/packages/viewer_handle_demo:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/packages/kinefx:/Applications/3Delight/houdini/18.5:/Users/helgemaus/Library/Preferences/houdini/18.5/packages/../SideFXLabs/18.5.469/SideFXLabs18.5:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/packages/viewer_handle_demo:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/packages/kinefx:/Applications/3Delight/houdini/18.5:&:&
HOUDINI_QT_PREFERRED_BINDING PySide2
HOUDINI_TEMP_DIR /tmp/houdini_temp
HOUDINI_USER_PREF_DIR /Users/helgemaus/Library/Preferences/houdini/18.5
HOUDINI_VERSION 18.5.462
HT /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/toolkit
HTB /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/toolkit/bin
JOB /Users/helgemaus
LOGNAME helgemaus
PATH /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home/bin:/Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/appsdk/bin:/Applications/Houdini/sidefx_packages/SideFXLabs18.5/bin:/Users/helgemaus/Library/Preferences/houdini/18.5/packages/../SideFXLabs/18.5.469/SideFXLabs18.5/bin:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/bin:/Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/toolkit/bin:/usr/bin:/bin:/usr/sbin:/sbin
POSE /Users/helgemaus/Library/Preferences/houdini/18.5/poselib
QTWEBENGINE_CHROMIUM_FLAGS --disable-gpu
QT_LOGGING_RULES qt.svg.warning=false
QT_MAC_DONT_OVERRIDE_CTRL_LMB 1
QT_MAC_WANTS_BEST_RESOLUTION_OPENGL_SURFACE1
QT_QPA_FONTDIR /Applications/Houdini/Houdini18.5.462/Frameworks/Houdini.framework/Versions/18.5/Resources/houdini/fonts
SHELL /bin/bash
SIDEFXLABS /Applications/Houdini/sidefx_packages/SideFXLabs18.5
SSH_AUTH_SOCK /private/tmp/com.apple.launchd.DhgyiDqtxM/Listeners
TMPDIR /var/folders/4q/l_fyqxbx3pb7yrnf008_w49w0000gn/T/
USER helgemaus
VFH_HOME /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home
VFH_IPR_ROP /out/vray_ipr
VFH_PATH /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/vfh_home/bin:/Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/appsdk/bin
VFH_ROOT /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462
VFH_ROP /out/vray
VRAY_APPSDK /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/appsdk
VRAY_APPSDK_PYTHON_REFERENCE_ONLY 1
VRAY_MDL_PATH /Applications/ChaosGroup/V-Ray/Standalone_for_mavericks_x64/mdl
VRAY_OSL_PATH /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/appsdk/bin
VRAY_SDK /Applications/ChaosGroup/V-Ray/Standalone_for_mavericks_x64
VRAY_SEND_FEEDBACK 1
VRAY_UI_DS_PATH /Applications/ChaosGroup/vray_adv_50050_houdini18.5.462/ui
VRAY_VFB2_ENABLED 1
VRAY_VFB2_SKIP_QT_RUNTIME_CHECK 1
XPC_FLAGS 0x0
XPC_SERVICE_NAME com.sidefx.HoudiniIndie.103828
_HIP_SHELFTOOLCOUNT 4
__CF_USER_TEXT_ENCODING 0x1F5:0x0:0x5C
any news on that? The nighties still crashing on my machine with 18.5.462.
Thanks,
Helge
Just tried build 10509 and seems to work. But will talk with dev if they can find the problem from your last post.
Loaded today build vray_adv_50050_houdini18.5.462_10534 and it works like expected.
Before that I deleted my preferences.
Don’t know, what exactly was the problem, but now it’s gone.
Thanks Georgy and sorry, if it was only on my side.
Helge
