“blur” from coordinates tab.
was it changed in VRay 5 beta?
It is accessible. These parameters are controlled through .coords (they aren’t listed through the ‘show’ command, that’s true; regular bitmaps do not list them as well). The command for the blur value is:
.coords.blur
For such occasions, keep an eye on the MaxScript Listener where parameter adjustments are printed, and take the code from there.
Just noticed some scripts that used to change it stopped listing this parameter. will work around it.
Thank you.
