I got strange problem with vray materil, means I dont have reflection on the material. All I do like always and always all was fine but some time ago I found problem with reflect.
All settings are normal, shader is really easy/standar, just gamma I have 2.2.
Please look to my shader setting, Irradiance map view and render.
Vray version- 1.50.SP5
Have you checked in the options material rollout where it has the reflection and refraction checkboxes. I know that when you do a convert scene to vray materials it creates a vray mat without the reflection turned on…
Thanks guys for replay but this is not it.
I tried turn on Reflection on back side and I checked Options slot in Mtl but still not reflection. Interesting thing is this happend only on the plane, flat model like floor/panels(before was OK so I don`t know why).
Ok but I found another way how I can see reflections is turn on Hilight glossiness and untick Fresnel reflections. New material setting in attachment and test 02.
