Vray 5.12 when I used noise reduction elements, I turned on noise reduction option in reflection elements. But the final result of rendering shows that the reflection elements still have not been de-noising
Can be normally de-noising next
Hi @q976431 ,
Seems to be working as expected on my end, see denoised vs undenoised result. Make sure that you’ve added the VRayDenoiser Render Element and the Denoise option is enabled on all the reflection/specular REs. Alternatively, do let me know if I’ve misunderstood you. Thanks!
Yes, that’s what I do. I use Intel noise reduction
I’ve turned on the noise reduction option in reflection. But only RGB images are denoised. Other rendering elements have no effect
Hi, Have you try V-Ray default denoiser?
