Normal Map and Specular in Mixture Shader
Hi there.
I bought Worldcreator and was using the Mesh in Cinema. I shoose Mixture Shader because the Tutorial was for Redshift.
Down below is my Panel and a render from the Mesh. The Mixture shader works for the Diffuse, but on the Specular and Normal Map i got Problems.
How do i have Setup the Specular and Normal Map if i want to use a Mask for the Shader ? Mixture Shader seems to have Problems with that.
Correction
