Normal map in a VRay material ?
Is there a way using normal map with VRay material ?
I put a “Normal bump” in the bump slot of a VRay mat with absolutly no effect (…and I works well with a standard mat).
VRay 1.43.09 and Max 8sp3
Khem. Can’t help here, I’m using 1.5 RCx :smile:
You should get a newer version of V-Ray.
I’d be very happy to have 1.5, but I waiting for my 2 dongles for about 3 weeks, with absolutly no news from Chaos…
btw I think normal maps are in 1.5 ?..
Thanks.
Fabrice
PROTOZOAIRE
You can install V-Ray 1.5 RC3 without a dongle, using your existing license.
As far as I could test here, normal maps work fine with VRayMtl.
Ok I didn’t know there was a dongle-free version of 1.5.
I won’t update now because 3 different works are actually on production.
Anyway…can normal map work with my actuals 1.47.09 ?
And how, I couldn’t make it…
:lol:
in other works stick with a standard map until you update.
If it doesnt work with vraymtl it doesnt work.
With 1.47 use a max material to get the proper effect
