Normal map map
Apologies for the late reply, was away for a few weeks :wink:
Thanks for that pointer Vlado :slight_smile:
So you can download this here for 3ds Max 2010:
Aaawesome!!! :smile: thanks several bunches!
Vlado, 3ds Max 2009 is forgotten.
Please build 3dsMax2009 version bump2normal.
I was wondering if someone has more complexe render using displacement mapping.
I mean other than 4 walls with brick texture.
Vlado, if you get a minute, would you be so kind as to crank out your bump2normal plug for those of us on Max 2009 too? =:o/
Thanks!
Here not work with max 2011
yeah a bump2normal build for 2011 would be awesome! Pleeeease Vlado pleeeeease :smile:
Bump…is this possible to recompile for max 2011 & 2012
VrayBump2Normal Plugin is already available for 3ds Max 2011 and 2012; V-Ray 2.0/2.1
Can someone help me about VRayBump2Normal ?
I don’t understand, It seem so easy to use that I certainly make a mistake… Nothing appear when I try to use it (max 2012/VRay 2.20.03) :frowning:
It works fine here.
Can you attach an example scene?
sorry ! It was a mistake, never mind
