hi team member,
i am using the trial version and it was running ok and producing good rendering but lately with some more trial i am seeing some problem with texture and color reading.
I am attaching one jpeg so dat u can understand the problem.
Are your faces reversed?
oh. thanks for the response, but all my surface faces are correctly oriented, is it some kind of enscape bugs
Could be the effect of atmosphere and ground plane, try going to atmosphere tab, and try different options for ground plane, white may fix this.
ok will try dat
@solo75287 thansks again for the suggestion but nothing happened, it still reading it incorrectly.
and once it starts reading incorrectly then everytime i open the file in enscape it becomes worse,
i hope the creator will look into this matter
Hi insilee,
just to be sure:
When you restart SketchUp and open Enscape for the first time everything looks good and after you do some changes in your model the textures in Enscape becomes wrong? Closing and restarting Enscape does not help, but restarting SketchUp helps (for a short time)?
If that’s the case, it must be a bug on our side. If you can find a precise list of steps that reproducibly leads to the problem we would be happy if you can send them together with the model you used to support at enscape3d.com
If that’s not the case, please describe in more detail the unexpected behaviour of Enscape. Again, we can help you better if you write to our support.
@Simon Weinberger, yes thats exactly is the case , when i add and delete some component in the model while enscape is running ,it starts showing abnormality, and doesnot go away even if i undo the thing.
its a bit large file and uploading it would be tough, but will try for sure
but one thing i found out that the problem is usually seen with the large file say more than 100mb, small size file size doesnot have problem. i am not sure but it might give a hint about the issue.
The file i am dealing with is fairly detailed for me to get a walkthrough video, so after optimising with the help of purging and cleanup3 plugin too didnot help to reduce much. it is still around 120 mb.
my system specs are:
core i3 2120
gtx 750ti oc
2TB hardrive
12gb memory RAM
lastly could you please direct me a link to the exact location of the support section to submit my querries
fixed in 1.9.3.255
