Having a bit of an issue with my ObjectID render element not appearing in multi-channel EXR files. Have tried 2.00.04 and 2.25.01 with the same result. Has anybody else encountered this?
Cheers,
Christopher
Cheers,
Christopher
Which program do you use to check the channels? It’s an integer channel, not a floating-point one and some programs can’t display it.
RV and Nuke.
We could run a post process to split that channel off into a solo file I guess (we’re post processing the multichannel exr anyway).
Is there something that is known to show this channel correctly, when everything else is half float?
Nuke shows it correctly from what I remember (though it might be in the “other” channels section).
Thanks Vlado. Got it sorted now. We’ve got an expression that allows Nuke users to visually ascertain the objectID is intact. Houdini’s mplay worked a treat and allows one to quickly check all channels too.
