office building
Trying out VRay …comments please
Re: office building
Wow, ;D Beauuuuuutiful…Did u photoshop the white watermark and drawing lines? or with sketchup?
Re: office building
I used this visopt DCgi_irmap_medium_pcam.visopt…I found it somewhere on this site…it is intended for exterior use I think but I don’t know if I can increase the quality resolution output…the “grainy” look
Pheranova: thanks for the comment, glad you like it!
Re: office building
here are some more images of the same school project that i am “redoing” because it had some real crappy renderings..
hope this is an improvement…would like to know that you think…
Re: office building
another one…
Re: office building
any replies? come on people! im practically begging here…
Re: office building
Hi
Your renderings look fine so far.
Maybe you need a larger brick texture to avoid the pattern repeat.
It really depends what you are trying to achieve; Stylised render, render of a studio model or a more photo realistic render. At the moment it looks stylised, in which case it looks the way you want it to look, but if it is more photo realistic then I assume you have still to place it in context (PS).
I suggest that you put an image (jpg or hdr) in the environment slot to get some reflections in the glass, which I think will give it more life.
Is this a school, or a school project? Because if it is a school then I guess you will be adding some clues as to its use - students, desks, signage etc.
Good luck
David
Re: office building
Hi madmax. I’m looking for DCgi_irmap_medium_pcam.visopt but i cant fin it. Do you remember where did you find it? and if you don, can you post your settings? many thanks!
Re: office building
I tried putting some people and trees into the image, I’m no expert on Photoshop and don’t know how to use clipmaps, etc… But these trees came out pretty decent I think
