Opacity map with depth?
Just curious. Would it be possible to implement a texture whereby the opacity map ‘cutouts’ can also have depth and enable a solid core to be shown?
e.g. holes drilled in veneered wood reveal the fiberboard core underneath to a user defined depth with the option of end capping?
It would mean that the geometry can stay very simple for objects that may have alot of cutouts and holes whilst being able to show some depth to the hole defined by the opacity map.
I imagine this would be possible with the OSL Parallax shader, where you could make tiny little window boxes around each hole (A cube is much more lightweight than a cylinder). Though the only thing I’m not sure about is how it would play with being rendered in Corona.
Maya example, but the technique would be same for the Max version: Playing with OSL #3: WindowBox Shader | Julius Ihle
As far as i remember OSL isnt supported yet or has that changed in dailies?
Duplicate: https://forum.corona-renderer.com/ Real thickness of materials with opacity
By the way, this is already possible in Corona to some extent. With Corona distance you can get render-time booleans with pretty spectacular results. It’s not very easy to setup and probably not aplicable to every scenario, but still..
Interesting, how is the plywood material appled inside the cutouts? Could you show a material graph?
I’m attaching scene, so you can inspect it by yourself.
Render-time-booleans2.7z (424 KB)
perfect thank you :smiley:
Clever… and confusing! Thanks for sharing.
I’m not claiming authorship of that idea, it was already shown by someone in the forum, as soon as distance map came around. I agree that it’s a bit tricky to setup and maintain this thing, that’s why we are all waiting for Corona slicer :]
Yeah i think it was Maru posted something similar after doing some digging.
Corona clipper object would be awesome. Hopefully its coming seeing I put a request in 5 years ago.
Ah thats a shame i didnt think it would affect render time that badly.
So i tried this as per maru’s tutorial and it didnt work
Ive attached my setup and the result.
It appears to be capping the boolean at a very small depth?
It’s probably would be best to attach scene for inspection. Most likely you did some mistake here, as i see no reason for such setup not to work.
Its the translucency applied to the acrylic material. I removed it and it worked fine. There are various major artefacts when using anything more complex than basic primitives however.
Ive noticed you get a really thin slice of the base object material before it changes to the inside edges. Is there a way to control the thickness of that edge?
Distance map is known to produce artifacts in some cases. If your cutter has sharp angles, you can try to add tiny amount of chamfer and see if that helps. Also try to subdivide intersecting objects - that might help also.
Are you using round corners on that material? Try to remove it and see if thin line disappears.
