(Open, Open, Open) [HOU-4574, HOU-4575, HOU-4576] VDB volumes rendering incorrectly
reaching out to you regarding VDBs in Solaris.
I’m currently working on a large water sim, and when importing my VDB from SOP, if put in volumetric mode it doesn’t renders. But if I put it in volumetric geo, it renders, but way farther in the scene.
I’ll put pictures that explains better.
Attached you’ll find a file with one frame of the sim and my setup up to date.
Btw I’m working on Houdini 20.5.278 and V-Ray 6.20.24​​
Hey @andrew_cyrmarcoux ,
We’ve identified a couple of issues that we’d need to resolve. I’ll get back to you tomorrow with more information as I’ll need to clarify with the development team.
Best regards!
This will take us a while to resolve - there are two unsupported cases happening there: (1) the non-uniform voxel sizes produced by the Volume Rasterize SOP when generating the VDB based on the camera frustrum, and (2) the “transform” primitive intrinsic attribute not being supported.
I had hopes that a VDB Resample would resolve (1) would help but then (2) popped up, and I have no workaround there.
The only suggestion that I have would be to generate the VDB without relying on the camera frustrum in order to circumvent these limitations.
Best regards!
