Orthographic camera - max 2016
Might be a stupid one, but I can’t seem to find it. With the old Max camera I was able to set it to Orthographic projection. But with the new Physical Camera this option seem to have vanished. I know you can set the camera to a FOV of 0°, but I don’t want to put my camera a million miles away and I know you can set orthographic in the render dialog, but then I don’t have a clue how that looks without rendering.
So how do I get an orthographic camera, in viewport and render without putting it on a 0° FOV.
Maybe you should use the old Target Camera and tick Orthographic projection on. Then use the Physical Camera exposure control.
Alternatively, in the V-Ray settings, in the Camera rollout, change the type from “Default” to “Orthographic”
How can I access this in max 2016?
Thx Vlado but then I won’t have a visual reference in the viewport.
I’m also interested in orthographic view… not often but sometime, we need it … so the best way was to use the old max cam with the Vray Exposure Control. It was fine especially if we needed to match with the other Vray Cams in the scene
So what is the best way to do it again ?
The old Max Target camera is still there:
Max 2016 >>
Works like a charm. Thanks
Can’t get the DOF working with this though. Whatever values I change in the override camera render dialogue for DOF nothing happens.
It doesn’t seem to work here either and I’m not sure if this is supported at all.
when was the “othographic” cameratype feature implemented ? did not find anything in the change log?
A very long time ago I think.
in the latest vray 2.5 there was no “orthographic”, there was “cylindrical (ortho)” . now in 3.3 we have a “cylindrical (ortho)” and also an “orthographic”. as we always used the standardcamera-orthographic with the vrayexposure thing we never used a vraycameratype.
for me it seems that the cylindrical (ortho) looks parallel around in a circle, and the new “orthographic” looks completely parallel (not rotated in any way)… so this would be the same as with the standardcamera “orthographic” feature. this must have come with any vray3 update
Anytime I need to do something like that I set the focal length of the camera to 300mm to 600mm and dolly in or out as needed.
