How can I set exactly the same ortographic views as I have in Archicad? Somehow I have a different angle in Enscape as in Archicad (Perspective views are all synchronized directly correctly). Maybe I´m doing someting wrong?
I would like to make Enscape-rendered sections/Elevations, so I could then overlap them with 2D vector-lined Elevations from Archicad.
Tnx for help!
Btw, it would be cool to have an option to search among these threads, so I could easily see if anyone already started a similar topic.
Or, I have an easier question When I am in enscape in orthographic mode, how can I set the view exactly on the top or side view? @Demian_Gutberlet maybe you know?
@tjasa , using keywords you should still find existing threads about the topics you’re looking for, of course only if there have been ongoing discussions before. The search function can still be a bit finicky sometimes, I have to admit.
Regarding your question though: You can always make use of the following hotkeys as well:
NumPad 5
Top View
NumPad 2
Front View (set direction of view to project north)
NumPad 8
Back View (set direction of view to project south)
NumPad 4
Left View (set direction of view to project east)
NumPad 6
Right View (set direction of view to project west)
NumPad 0
Return to the currently selected Named View
PageUp / PageDown
Previous View / Next View
I hope this helps, and hopefully, you do actually have a NumPad section available with your current keyboard.
