I can’t seem to get the Override material option to work in RT. I’m using 3.60.01. Anyone else get it to work?
It seems to work fine on a simple test scene. Can you attach an example scene with the issue?
I’ve got a gray material override set on this, but it in RT mode renders with the colors. I’m clicking the Start Interactive Rendering button in the VFB to start the rendering.
Vray RT Mat override test.zip (87.1 KB)
You meant that the IPR is not working correctly? I logged the issue.
Yes, my bad. Thanks for looking into it.
It turns out this is not a bug. Actually if the RT is set as a production renderer then the IPR button in the VFB uses the Active Shade settings instead. The only setting that it takes from the production renderer is whether to use CPU or GPU for the RT. Therefore you just need to set the ActiveShade override mtl instead when using this setup .
