Painting a house
2024, can I export a house built in 3DS MAX, import it into something else, paint detail onto it, and merge it back into MAX? UVW mapping hasn’t changed in 20 years, so there has to be a better way. I know Adobe has Substance Painter, but I am unsure if that is a good fit. It seems like it is something we can do in 2024.
dont feed the troll please
What does that mean, he asked a question, that’s what the forum is for.
Depends how clean you want your uv’s while managing each asset through production.
unwrella offers a “one click” solution for unwrapping and packing UV islands within that space, but for what you’re asking for that may be unnecessary.
since you want to unwrap a box basically you could unwrap each elevation and layout your uvs that way and paint it any number of ways.
you could also do it per face in z brush or mud box but you’re limited to editing the generated uv maps within each of those apps since your uv maps essentially become garbage to work with as it randomly packs each face.
substance may offer a solution for this but I’ve never used it.
either way it’s going to require some homework on your end to figure it out.
If you do decide to learn the art of unwrapping, you’ll need one of these:
I blocked him long ago, and I don’t see his posts. Ignore him; he is rude and needs to go away.
Yeah, unwrapping seems to be so 90s. Why can’t I open my house, spin around it in 3D, and paint where I want to? Just like 2D in Photoshop, just in 3D.
Ummm… you’re missing the concept entirely…
you can do just exactly that. But first you must have an understanding of how the UV coordinate system works…
this is a universal concept of how x,y,z (Cartesian/3D) and u,v (planar/2d) work together
be careful out there!
I get it, but it is way too complicated. Do you remember Piranesi? I am thinking that, but in 3D.
lol
Stay safe out there!
Has AI hacked you?
Again, the answer is yes.
Do you know what this is?
Here’s a clue
Here’s another one
And another one
Substance painter is incredible. You can automatically unwrap inside there, and it’ll be fine for most objects.
However the workflow in principle is still the same from decades past. The software still needs to generate a texture map, and to do this it needs UV mapping. Without unwrapping, the texture will be incorrect, and won’t work, just like trying to lightbake a model without unrwapping.
I’ve used Unwrella in the past to automatically unwrap objects in Max, and it’s very capable.
The only thing you need to really think about is texture map size, and the areas of the model you’re unrwapping. If you have a building for an exterior CGI, you’ll want your unrwapping to focus on the exterior walls, main facades, etc. There’s no point in using texture space for the interior or underside of objects, as these won’t be seen.
Unwapping isn’t hard, once you get fast with the tools.
Very well said, suzanne
Sorry me for actually not being the good guy would you?
this mess of what Chaos has now become will impact us all, even smaller guys like the one who blocked me years ago and still bribed today about it.
this is basic knowledge he should have done research elsewhere…
please keep the forum clean don’t feed it too much for no reason, keep focus and long life to the dev’s!
