Particle Preview Wish
Right now it looks like if your Foam (for instance) has RGB values then the particle preview always shows these RGB values. It would be nice to be able to choose to show a user selected color in the viewport, like you get for Foam without RGB properties saved. So basically it would be nice to have a toggle for the RGB display of particles, ideally this is per particle type.
Thanks.
Oh yes, the particle preview needs a major rework, right now there’s a lot of stuff hardcoded to the most common use cases.
