Particle Tuner keys in timeline
Hey
as title suggests, I have animated values in my particle tuner, would be nice if I can slide these keys around in my timeline. I tried all the different filters in timeline menu , but still didn’t show up ( using max 2020)
these tuners are amazing by the way :slight_smile:
Hey,
Which values do you have animated? From what I can see the “Then” conditions are showing up in the timeline? Are you animating the values inside of the Edit condition window?
Thanks!
Ah, the Voxel Tuner is creating each expression as a hidden node in the Scene explorer, if you select it in the Scene explorer or in the Curve editor the keyframes should show up.
Though if you have the Voxel Tuner selected and the Edit Expressions window is open the keyframes would show up only in the Curve editor.
Hope this helps. ​
oh nice, ill give that a try :slight_smile:
thanks
