I thought this was possible…is it in any way?
I have a collapsed model that I need to control the spill for in one material.
EDIT: Disregard; it’s in the wrapper of course ![]()
Or the Vray Properties, if the node has one shader only applied (or you’d like the change to affect all the materials on the node).
Thanks but that is per object - mine’s a multi-sub ![]()
All sorted anyway; I was very tired when I posted and realised exactly 3 milliseconds after I pressed ‘post’ ![]()
Also the adjusting the GI amount under the Vray Properties has no effect for Vray Next GPU.
